are all adjustable masters created equal ?
I see several vendors offer them but mostly see a lot about ticks version....
but strano has one for $189.00 and I will be cheap if its not going to come back to bite me in the **** so any help eduacting me as to the differences from one vendors unit to another without bashing anyone will be appreciated
LS1TECH Sponsor
All Adjustable Masters are certainly not created equal.
Only two are capable of a significant fluid flow increase over a stock cylinder, the Tick Performance Adjustable Clutch Master Cylinder and the McLeod. The rest (Ram, etc) are just stock cylinders with an "adjustable rod" installed that allows you to remove the dead space from the pedal. The problem remains: these hydraulic systems need MORE FLUID in order to function properly.
Our kit is built around a Tilton Master Cylinder, the same one the NASCAR guys use every Sunday. Our kit is very well built, made in the USA, and covered under a warranty against leaks for the entire time you own it.
Our kit also comes with a heat-wrapped, unrestricted stainless braided line that eliminates the need for the "drill mod" so many have wasted time trying in the past.
For more info, read here: http://www.tick-performance.com/imag...kshiftfaq.html
