front swaybar: Energy Suspension vs OEM
I thought I'd decide to upgrade everything up front with Energy Suspension parts based on search results of this forum. I have SLP's 35mm bar. The bushings SLP sent with the bar came reused the OEM brackets. SLP also gave me some new end links, which looked exactly like the OEM ones.
I bought Energy Suspension 9.8118 end links and 9.5168 1-3/8" bushings. The end links look too long and the bushing + bracket looks flimsy as hell.
Should I just get a refund?? Or is this how it's supposed to be?
The "installed height" of the endlinks should be such that the "arms" of the sway bar are as close as possible, to being paralell to the ground, when the car is sitting at "ride height". Any change in ride height, due to lowering springs, etc, will most likely result in different length endlinks being needed. Energy Suspension makes a variety of endlink sets, in different lengths, specifically for this purpose.
