mail order or email speed density base tune?
is there such a thing as a "base" tune for my truck (also converting to speed density) that would get me able to drive it safely this weekend, light / part throttle?
i tune with Hp tuners, but wasnt going to tackle the speed density conversion my self...
i got it running last night with the stock injectors...
my combo is one of the simplest bread n butter combos out there...
its a 6.0, ls6 cam, tc78, bosche 73lb/hr injectors at 43.5psi(i have injector data and ir table for base pressure of 50psi.) have a wideband, adj. fuel press. reg.. etc
two walbros etc
(btw its a 411 computer from a 2001 silverado in a 99 gmc sonoma...)
if this is anywheres even in the ball park let me know. if it were cost effective compared to the real dyno tune and would get me started i would be interested in buying a tune from someone as long as the combos were very similar...
two walbros etc
I can get you setup, either through a base tune, or even remote tuning, where I log in to your computer and get it setup/dialed in for you. I do it all the time. Helped a guy out last night via remote. He was tuning a kenne bell LS motor, 2 bar speed density.
You'll need wireless at your truck.
If you're interested, send me an email. edcmat-l1@msn.com
