o2 sensor question
o2 sensor question
my car was getting terrible mpg so i replaced the o2 sensors and it worked for about 300miles. now its getting 12mpg again. it has a low voltage o2 bank2 code and thats it. the tune up is up to date as i just replaced air filter and plugs recently. any ideas
Not uncommon to have 02 problems with LT's. Some people just have the code tuned out. Or widen the parameters that will trigger it. This is just what i've read. What kind of 02's are you running. Some people have good luck with the Bosch 13111's (corvette C5 rears). Do you have 02 extensions or are you running a long 02? These are some of the questions you will be asked. Also, if you search you will get a mindblasting amount of info on this issue. I know I have.
