Driveshaft for TH400 to 10 bolt???
Old 09-14-2011, 12:52 AM
FasTimeSS's Avatar
Default Driveshaft for TH400 to 10 bolt???
I need to know where I can get a driveshaft for my th400 swap to hook up to my 10 bolt. Also does anyone have the measurements? Any help is appreciated. Thanks
Old 09-20-2011, 07:46 PM
ODAWG's Avatar
call umi
Old 09-20-2011, 08:11 PM
FasTimeSS's Avatar
OK I will tomorrow thanks
Old 09-21-2011, 09:37 AM
LS1Tech Premium Sponsor
MidwestChassis's Avatar
We can get you into many different drive shafts. How ever it is best you take the proper measurements that way you get the drive shaft you need for your particular application.
You want to have the vehicle at ride height and measure from the seal of the transmission tail shaft to the center of the u-joint on the rear end.
You will be after the "X" measurement.
Quick Reply: Driveshaft for TH400 to 10 bolt???
