lq9 dbw + t56 -- engine sluggish.
I have a lq9 dbw pcm 12589463, along with all the appropriate tac and pedal from the same car (2005 cadillac escalade). After some disabling of things, I got rid of most of the auto related codes. I disabled all the torque management stuff based on this guide:
http://www.hptuners.com/forum/showthread.php?t=23766
I'm running the car in open loop right now because one of my bank 1 o2 sensors is bad -- but this shouldn't affect the WOT tables.
I know something is up because with a 2.05 60ft, i ran 14.0 @ 95 mph in a 3000lb rx7 consistently. According to ET calculator, the car is making 200whp based on the mph and weight.
No codes are being thrown right now. What did I miss? I have a feeling the ecu is causing something to be up. The engine sounds fine! I will be compression testing/leak down testing it later today.
