Using truck coils, clearance issues
Old 09-19-2011, 09:09 AM
arthropraxis's Avatar
Default Using truck coils, clearance issues
I am using truck coils on my LS1 because of clearance issues with my master clyinder. They worked great on the drivers side. On the passenger side I am having clearance issues with my fuel inlet to my fuel rail. How have others dealt with this?
I could bend my fuel rail inlet, not really liking that idea. Relocating the offending coil could work. But, that was the reason I went with the truck coils, I was told it was bolt on and I wouldn't have to relocate anything.
Ideas?
Old 09-19-2011, 09:19 AM
Strokinit383's Avatar
Tape up the inlet and slide a deep well socket over it. Carefully bend. Done!
Old 09-19-2011, 09:31 AM
thunderstruck507's Avatar
I did mine exactly as Strokinit383 suggested. Doesn't take much to make them fit.
Slow and careful is the only real advice.
Old 09-19-2011, 09:42 AM
Thanks, for the advice. There is a little brace welded from the inlet tube to the fuel rail. Does that need to be cut to allow the inlet tube to be bent?
Old 09-19-2011, 09:43 AM
Nope! I didnt have to. It should bend fairly easily.
Old 09-19-2011, 12:41 PM
46Coupe's Avatar
Like these guys said. I bent it out of the way a little bit.
Old 09-19-2011, 02:27 PM
Thanks, for everyone's input. I will bend it out of the way.
Quick Reply: Using truck coils, clearance issues
