Innovate LC1 problem.... ugg
Just installed my wideband LC1 yesterday. It worked great all day yesterday and part of today. I was driving it today and it was reading my AFR just fine, then all of a sudden went to "7.4" and started flashing. The red LED stayed on the whole time. So i looked up some culprits and found out if it gets too hot, it will do this, so i popped the hood and sure enough, where i had it routed, it had somehow worked its way onto the header. i adjusted the big connector and got the wires off the header and away. Started it up and drove around for about 10 min and it worked fine. then it started doing it again. It will flash "7.4" then go to like a solid 8.5 for a few seconds, then start flashing 7.4 again... Any ideas what the **** is up with this thing.... ??? sry for being so long.
