Category: Engine - Complete Motors
Price: $5000
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, 04-06 Pontiac GTO
Location (State): TX
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
I have a 6.0L iron block with a melling high volume oil pump and arp rod bolts. It has an LSR custom grind cam that makes power from 2200-7200rpm. The heads are the 243 casting from texas speed PRC stage 2.5 but then i took them to LME to get more work done on them. Im going to put it on a dyno on october 1st to see what kind of numbers i get. It has a Fast 90/90 but accesories will not be included except for an underdrive pulley. It will have a GTO t56 trans also with an ls7 clutch and slave. So all you have to do is drop it in. Im trying to see if i can sell for $5000.00 o.b.o. if not then ill drive it till my new setup is done and then serve as back up.
Engine is still in the car and im in the houston area, so if your interested please email me at
rigo0@yahoo.com
