how low do f-body headers sit in chevelle
Old 09-22-2011, 12:21 AM
massen1981's Avatar
Default how low do f-body headers sit in chevelle
as the title says, how low do they sit i a chevelle???
Old 09-22-2011, 03:56 PM
downset71's Avatar
depends on where your motor sits vertically on chassis. but that doesnt answer your question. what i have been askin for monthsm and nobody ever answers me is how do they sit in relationship to the motor itself. lets say an f-body pan for reference. which "hangs" lower, oilpan or f-body header? with this information you will know to raise or lower mounts in car so exhaust doeesnt scrap ground
Old 09-22-2011, 04:28 PM
bczee's Avatar
This is not something that is something that is no adjustable... . Generally Headers are close too if not even with the Bottom of your oil pan's lower sump. Most of the time F-Body pan well be at or above the bottom of your front crossmember, unless you make an effort to mount it lower in the front frame/crossmember.
Truck ones would hang a bit lower than a Car (F-Body) header.
Quick Reply: how low do f-body headers sit in chevelle
