change computer now car do not start
Old 09-24-2011, 03:28 PM
LEEEPPS74's Avatar
Default change computer now car do not start
swap computer now will not start put old pcu back still no start , when you swap computer do you have to take battery cable off ?
Old 09-24-2011, 07:33 PM
tsench's Avatar
check your pcm fuse and for the new pcm to work you need to flash your vin in
Old 09-24-2011, 09:18 PM
LEEEPPS74's Avatar
Default wher is pcm fuse at
wher is pcm fuse located at ? in what fuse box ?
Old 09-25-2011, 11:40 AM
tsench's Avatar
on the left side of engine check and see there is 2 fuse box there get a test light test each of them i cant remember wich one
Old 09-25-2011, 08:54 PM
LEEEPPS74's Avatar
Default that fixed it
i found the fuse was blown , and found out that after i plug pcm in it shorted out and blow th e fuse , i got this from the guy i got the engine from but his car is a99 and mine is a 98 so i guess this pcm will not work in my car
Old 09-25-2011, 10:42 PM
tsench's Avatar
nope 98 is unique 99-02 are difference or you can repin your harness to take 99-02 pcm
