ideas how to get my car to sit right??
Old 09-26-2011, 11:47 PM
chadroosa's Avatar
when i got my car it had bmr rear springs and hose mod.. i put hotchis front springs on and it still looks like im doin a hole shot jus sittin there, not as bad as before but i want my front to come down more.. any suggestions?? will they settle been about a month and hasnt settled that much..
heres how it sat when i got car
Old 09-27-2011, 12:04 AM
Restricted User
z99ls1's Avatar
Doesn't look bad, but it could sit just a little bit lower in front. Buy a heavier battery LOL
Old 09-27-2011, 12:08 AM
chadroosa's Avatar
lol nice
Old 09-27-2011, 08:49 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Are you using matching spring sets for the front and rear? You sig shows Hotchkis fronts and our rear springs. Did you buy the car with our front and rears?
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 09-27-2011, 08:58 AM
Camaroking1996's Avatar
IMO the rear looks a little too low from the first and second pic i like the way the front sits
Old 09-27-2011, 11:18 AM
chadroosa's Avatar
yea car had bmr springs already installed when i got it and came with a set of hotchis front springs, so i installed them, imo stance is everything its about half an inch or so lower in the rear than it is in the front needs to be at least level or quarter inch lower in the front..
Old 09-27-2011, 12:48 PM
ramairetransam's Avatar
raise the back with the stock isolators . and add a procharger to the front to lower it some.
Old 09-27-2011, 01:22 PM
chadroosa's Avatar
lol you give me parts and ill install them...
i kinda like the look of the rear, want front too sit down more, other than hillbilly cutting front coils, or coil overs pretty much stuck with it, u think itll settle anymore?? rear springs look like they where older and already settled.. so dont think they will go down any more. so just gotta worry about the front
Old 09-27-2011, 02:18 PM
BMR Tech2's Avatar
I want to say there is something else wrong your here. The front of the car should be considerably lower than it is. Could you possible take some pictures of the springs installed and email them to me at kevin@bmrsuspension.com
There shouldn't be this much wheel gap.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 09-27-2011, 05:23 PM
JD_AMG's Avatar
So you have one brand of lowering springs in the front, and a different brand in the rear, and you are asking why your car doesn't sit right?
Old 09-27-2011, 05:59 PM
chadroosa's Avatar
I don't think the two differnet brands is the problem, how much does the heater hose mod usually lower car??
Old 09-27-2011, 06:00 PM
i6overboard's Avatar
The back looks perfect, go and get set of front coilovers to get the stance exactly how you want it. It took a few adjustments for my setup but its way worth it to be able to adjust it.
Old 09-27-2011, 06:01 PM
chaman's Avatar
Wrong. That could be your problem.
Old 09-27-2011, 06:02 PM
chadroosa's Avatar
What brand coil over u use??
How could that be if one brand is supposed to lower it 1.5 and the other lowers an 1.5 they r both 1.5.
Old 09-27-2011, 06:08 PM
I have a set of SA strange's. Cant cant complain about them so far. Also the doing the heater hose on top the drop springs is why the front to rear is so drastic.
Old 09-27-2011, 06:11 PM
chadroosa's Avatar
I think problem is that rear set of coils is old and has heater mod, and fronts are brand new.. older the spring is the more they sag.. jus don't know y whoever had car b4 me would only lower the rear and drive it like that..
Old 09-27-2011, 07:34 PM
JD_AMG's Avatar
Hotchkis is 1", BMR springs are 1.25" drop...
What color are both of the springs?
Also what size wheels/tires are on the front and rear, don't go by what the guy told you, actually go out and look at your tires and read the ratings on the side before you reply.
Old 09-27-2011, 07:47 PM
chadroosa's Avatar
Bmr springs are red and hotchkis springs are grey, I called hotchkis and they told me fronts are 1.5.. tire sizes are front 265/35/18 and rear is 275/35/18
Old 09-27-2011, 07:54 PM
babbage1109's Avatar
If you put the isolators back in it wouldn't look half as bad as it does. It looks like one of those shot out caddies that drags the *** on the ground
Old 09-27-2011, 08:40 PM
chadroosa's Avatar
Lol yea doesn't look good
Do you have a pic of your car so I can see how it sits...
