Had Driveshaft made: Problems
Old 09-27-2011, 07:44 PM
70hemicuda's Avatar
Default Had Driveshaft made: Problems
I measured where the shop told me to measure(From the seal on tranny, to flange on 8.8) Go to put it in, and there is no movment of the driveshaft for travel. What are my options? Preferably cheapest. Thanks in advance for help
Old 09-28-2011, 02:08 AM
Big Al's Avatar
Go back and tell them. You should have a minimum of 3/4 inch of movement minimum.
Al 95 Z28
Old 09-30-2011, 08:10 AM
lttransam's Avatar
yeah if you dont have any movement you will break your bellhousing, ask me how i know lol ..
Old 10-02-2011, 07:50 PM
ss84carlo's Avatar
70hemi. I build shafts full time. A common mistake made when measureing a shaft is suspension travel. make sure that the susp is @ ride height when u measure. if your measurement is correct measure the shaft. If its there mistake they should cover the shorten. If its your mistake, and if I told you how to measure you pay half price. Unless your a *****.lol
Also I always measure from tip of tailshaft to Face of Flange. Rather than seal. Cause of seal to tailshaft distance can often screw u..
Old 10-03-2011, 10:05 PM
70hemicuda's Avatar
thanks. I got it shortened and the 8.8 is in action
