Check my wiring idea plz
Just wanna make sure this is correct this is for switched power to arm button. I was thinking power from battery or ignition switch goes to arm switch then to msd window switch then to my zex box right?
It depends what you mean by "then to". If you mean that your window switch and zex box are only powered when your system is armed, then, no, that is not correct. Your arm switch and window switch and zex box all need to be fed from switched power. The wire path doesn't matter.
1 Post
Your statement is pretty vauge. Considering that the window switch has mutiple wires. I have mine coming off the battery to my arm switch (fused 10 amp) then from the arm switch it goes to the "switched power" on the window switch, and you will have to determine which wire on your particular window switch is made to activate your solenoids. My window switch actually switches the ground wires to the solenoids.
