What HP are you running with the Corvetter regulator?
Old 10-01-2011, 09:11 PM
66 BADBOY's Avatar
Default What HP are you running with the Corvetter regulator?
Hey guys,
I'm doing a swap into a 66 Nova. The plans are staying with my stock sized LS1 bottom end (relief cut pistons though). 228ish cam from EPS, Stage 2 TEA 243 heads, LS6 intake, 4L60e trans, etc. Running a Bosch 044.
I'm HOPING to use the Vette regulator setup from Wix. What kind of HP are you guys running successfully with this regulator?
Thanks!!
Old 10-02-2011, 08:04 PM
cam
cam's Avatar
Should work fine. I ran a very similar set up with the Vette Filter for years. Stage 2 heads. TR224 112 cam, LS6 intake etc. Never a blip
Old 10-02-2011, 08:21 PM
SweetS10V8's Avatar
I ran 410rwhp through it. A buddy of mine is running 435rwhp. I think the pump is more of a concern.
Old 10-02-2011, 08:33 PM
66 BADBOY's Avatar
Thanks for the quick replies guys!!
What size lines did you run? Seeing that the vette reg is 3/8", I was going to use -6AN line as well. I'm wondering if trying to switch to -8AN might not be worth it due to the vette reg as a choke point for line size.
Any thoughts on that?
Old 10-02-2011, 08:41 PM
Rocketrod's Avatar
You will be fine with -6 for your current setup. You dont have to go larger until around +600hp.
Old 10-02-2011, 10:16 PM
gMAG's Avatar
As SweetS10 said, the issue might be more about the pump than the regulator.
Under higher horsepower demands, the regulator will be more effective by mounting it closer to the engine.
Old 10-02-2011, 10:25 PM
2165 Turbo Rail's Avatar
535hp/558tq to the wheels on 8psi this was on an external walbrow 255 I now use an external Bosh 044 pump
Old 10-03-2011, 02:50 AM
wayne33's Avatar
good info, thanks
Old 10-03-2011, 06:11 AM
66 BADBOY's Avatar
Thanks for the replies everyone. I know the 044 will be fine for what I need. No doubts there. Looks like my plans will work great.
THANKS!!
Old 10-03-2011, 11:22 AM
FastKat's Avatar
The Bosch 044 is a monster. I think there was one for sale over at PerformanceTrucks.net
Old 10-03-2011, 09:49 PM
the_merv's Avatar
Vette Regualtor and a Walbro 255 on mine..it's got 60lbs in the Rails at 7000rpms, Z06 42lb Injectors.
