ms4 cam and forged bottom end?? nitrous?
i have an ls1 with forged wiseco pistons and eagle h beam connecting rods but a stock crank, 243 heads that were milled and it is 11.5 to 1 compression, and a ms4 cam with a 112 lsa. the motor has about 5k on it. my question is, will my setup take well to nitrous? also how much do you think my bottom end can handle? i was thinking of spraying a 300 shot at it. thank you very much for your help!!
I had a 150 dry with my ms4 on a stock bottom end and never had an issue, my car trapped 129 almost 130 on it @ 3600lbs. Put some NGK- BR7EF plugs in it and at least a 200 shot on it.
thanks guys! i have a 125 shot on there right now with b8efs and i have a nitrous outlet plate that i am going to install and i wanted to get at least a 200 shot on it. will i max out my fuel pump? also can i run 93 with a 200-300 shot?
ok i will. if i wanted to spray that a 250-300 could my bottom end handle that? also will my pump be able to keep up? when i was on a stock bottom end i sprayed a 175 with a stand alone but i sold the stand alone to get the fuel pump i have now. i am not really new to nitrous, i just want to know if my setup now will take as well to nitrous as my set up did when i had a ms3 cam.
no i have forged pistons and rods. i had a ms3 when the bottom end was stock and it took very well to spray but i have a ms4 now and i mainly want to know if the ms4 will love spray.
With your piston/rings/rods you will be fine spraying 250 shot with the right tune
you shouldn't just through that big jetting into your plate from the 1st time .. start with 100 shot ,, step then to 150 shot ,, and make your way up watching the AFR, Timing, Nitrous & Fuel pressure on each step
A stand alone fuel system is very recommended on bigger shots, you can run C16 in the standalone for nitrous and running N/A on 93 pump gas in your stock tank
With your piston/rings/rods you will be fine spraying 250 shot with the write tune
Come on man, your setup with 250 shot will make over 650 rwhp and over 700 rwtq ! .. that power level on LS1 is really worth pulling the trigger on standalone
What plugs you gonna use ?
Personally I have done 150 & 175 shots on 93 pump gas but above that I used c16 in stand alone fuel cell
right now i have a set of b8efs in the car. what do you recommend?
thank you for the info. i have Dave's plate as well. would i be able to run 100 octane and a 250 shot? i really dont want to run a stand alone.
