what are my options on a new output shaft?
Old 10-07-2011, 07:00 PM
StangEaterSS's Avatar
Default what are my options on a new output shaft?
the output shaft on my t-56 snapped clean off and is stuck inside my driveshaft. is there any options for an upgraded shaft or something that is hardened? where can I purchase these parts?
Old 10-07-2011, 08:38 PM
thesource's Avatar
Convert it to a 30 or 31 spline mainshaft.
Old 10-10-2011, 03:56 PM
I see the viper shaft conversion is $600 for parts and to have it torn down and installed i'm into big money. i'd like to go with another stock shaft. wheres the cheapest place for t-56 parts?
Old 10-10-2011, 05:15 PM
thesource's Avatar
Its the same process to replace the stock mainshaft versus the larger one except you have to bore the tail housing out for the larger bushing and seal.
Old 10-10-2011, 05:51 PM
I can get a stock shaft from GM with an employee discount for $120. I think i'm gonna go with the stock GM one from my dealer. the viper upgrade is $600 plus someone machining the tail housing. easily a $500 differnce. I cant afford that right now. I just need the car back on the road.
Old 10-10-2011, 06:46 PM
thesource's Avatar
$120 is cheap. I don't think you find it cheaper than that anywhere brand new.
Old 10-10-2011, 07:40 PM
TDP
TDP's Avatar
Yeah 120 is really cheap. Go for it.
FWIW, I charge $700 for all parts and machining and the yoke for the 31-spline conversion.
Quick Reply: what are my options on a new output shaft?
