LS1 in a fox with a Ford Tremec 3550. Is the VSS adaptable to GM computer?
Old 10-09-2011, 06:10 PM
BrianI's Avatar
Default LS1 in a fox with a Ford Tremec 3550. Is the VSS adaptable to GM computer?
Would it be the same signal input for the LS1 computer? If not, is there a way to adapt it? I want to run a Ford tranny but I don't want to lose driveability.
Thanks
Old 10-09-2011, 06:28 PM
SN-95's Avatar
Check out Dakota Digital, I think the have a box that will fix the signal if it's not right. I think it's pn sgi5
Old 10-09-2011, 08:43 PM
LS1MCSS's Avatar
Thanks
How many wires come out of the ford VSS? If it's two, then it's the right kind of signal, although I have no idea what pulse rate it will be.
Old 12-08-2011, 06:31 AM
BrianI's Avatar
Yes, its 2 wires. I'll have to look into the pulse rate and see what the difference is
Quick Reply: LS1 in a fox with a Ford Tremec 3550. Is the VSS adaptable to GM computer?
