More harness questions
Currently building an 87 S10 with a 5.3 and 4l60E. My question is, can I use the harness and comp out of a 1999 2wd 1500 v6? I have the whole truck, so i can use everything from the fuse block to the gauges. I understand that I may need hp tuners or some reprogramming software, as well as having to rewire for the injectors etc, but is this a viable option? If not what would you recommend? Thanks in advance.
