How Important Is Battery Charge On An LS1?
In other words, will an LS1's computer function the same, on say, a half charged battery, versus a fully charged battery? I have used Bosch EFI engines in years past, that were down on wide-open throttle & power, if the batteries were'nt perfectly charged up at all times. Just wondering if the F-Body LS1's computer was the same? Thanks in advance.
Rule of thumb is that a PCM needs 10 volts minimum to work. If you drop to or below 10 volts during cranking the PCM will not fire the coils or injectors.
Granted, this is just a rule of thumb, somebody out there will surely claim that they can crank and start their car on 2 volts.
