What is the -03 line flow limit
Just wondering if I will encounter and problems here. I am planning on spraying a 200 shot and was wondering if a 3an line will support that (from solenoid to plate). I am running Nitrous Outlet's plate and the fittings on the plate call for a 3an nut. I am using a 4an main feed line for both nitrous and fuel, but was wondering if I purchased 1/4" to 3an fittings (for both solenoids) and (2) 3an lines (from solenoids to plate), would it support up to a 200 shot?
Thank you in advance!
