How to Convert SS Tach from Coil Signal to ECM Signal
Does anybody have experience converting the tach output signal from an '00 LS1 ECM to work with the factory '72 factory SS tach setup? I have found some posts on various other forums regarding pull up circuits, signal buffer circuits, etc. but nothing that is the universally accepted solution for this issue. Any help or links would be appreciated. Thanks.
