t56 in a 1972 nova swap
Old 10-14-2011, 04:38 PM
Project66impala's Avatar
Default t56 in a 1972 nova swap
i have a hydraulic throw out bearing and what not.BUT my question is with the nova 4 spd pedals which master cylinder should i use from wilwood or tilton? i have a 600 horsepower ls3 .if you have done the mastercylinder swap how is the pedal feel and how is the shifting @ higher rpms? please thank you for any help in advance
Old 10-18-2011, 03:50 AM
randomninels1nova's Avatar
When I did my t56 I used the wilwood master, worked fine even at higher rpms... The only thing I would change is adapting a pedal stop to the pedal assembly. Good luck
Quick Reply: t56 in a 1972 nova swap
