Dynotune nitrous gauges- any good?
I'm pretty sure I want to install a remote nitrous gauge. Plan to put it in an AutoMeter cage mount gauge pod (2 1/16). I've been looking at options and the Dynotune gauges make good claims to accuracy and cost less than most too. Can anyone confirm or deny how good they are?
Most helpful would be a pic of the sending unit installed. I need a single 1/8 NPT connection with wires on the other end, not some sort of inline thing that can't work with pre-installed components from other companies (my stuff is all Nitrous Outlet). Can't find any pics of the sending unit and way the instructions are worded makes me wonder if it will work with my setup.
Also wondering if they ship quick, provide good support, etc.
Thanks guys!
Tom
Thanks guys!
Tom
They are 1/8 with a connector for easy disconnects when refills are needed. The the other side of the quick connect has all the separate wires for you to wire up. Plenty of length to work with and insulated for a clean setup. I've used them in the past and am happy with their products
