mechanical throttle vs electric throttle
Old 10-15-2011, 05:04 PM
Turboswede's Avatar
Default mechanical throttle vs electric throttle
I have found some lm7 in Sweden but most of them got the electronic throttle.
Is it harder to use them in a swap then the mechanical throttle engines?
Is it possible to swap electric throttle to mechanic easy?
Feels like would be a better feeling in the mechanic One?
Old 10-16-2011, 08:06 PM
Tappet Head's Avatar
Pretty sure its quite easy yo convert to a mechanical, but if you can get the complete pedal assembly as well as all switches wiring and sensors, you could easily use the electronic throttle.
Old 10-16-2011, 08:12 PM
82cetuner's Avatar
you have to match ECMs also with the mechanical or eletric
Quick Reply: mechanical throttle vs electric throttle
