GLIDE to LS1 flexplate question!!!!
hi all need help with this question.
i have an LS1 and a powerglide.
what sort of flexplate do i need?
Does the standard fit, or is there an aftermarket one i require?
cheers
Paul
cheers
Paul
The PG will probably have the LT/TH350 bolt pattern. Which is on a 10.75" circle. We have a SFI rated flexplate for you with both the LS and LT holes. So it will meet the safety and conversion requirements. You will also need a pilot extension. The LS crank requires a longer converter pilot than the standard GM setup. We have those as well. Give me a shout and we can help you out.
Chris
Chris
