Gforce Engineering Customer Appreciation Sale
That's right folks, it's time for the Gforce Engineering's customer appreciation sale.
We had planned on having it around Labor day but we had just started moving into our new shop and we just didnt have time.
These prices are not shown on our web site, they are for our fellow forum members only. It's a way for us to give back to the forum members that have made us the #1 drivetrain manufacturere of choice for the GTO community.
To order, give us a call or shoot us an email or PM.
And some exciting news..
I would like to tell everyone about our new warranty.
We have decided to go to a "LIFETIME" warranty on our products.
That's right, Lifetime.. If you ever break it, we replace it.
We very rarely have to replace parts under warranty, we only use the best material available and we design our parts to hold up to what we say they will.
Our old 2 year warranty was the best in the business and our new Lifetime warranty just goes to show how much pride and confidence we have in our products.
The Lifetime warranty is non transferrable, meaning if a customer buys a Gforce part then it is covered for the life of the vehicle under that owner. If the part is sold then the warranty reverts back to our 2 year warranty.
We will start sending warranty registration cards with our products or you can print them off on line and send them in. That way once your product is registered you can simply forget about it and we'll just keep it on file.
The lifetime warrany only covers parts manufactured by Gforce Engineering.
And now on to the sale..
Level 1 4340 axles (750 rwhp) - regular price $799. sale price $699.
You can get these in the standard diameter or the Anti wheel-hop set for the same price.
Th #1 selling axle in our line up.
Our Level 1 axles should really be called Level 10 axles, they have been 9.20's pulling 1.34 60ft times from a nitrous car that happens to be the fastest GTO in the country with a factory GTO rear. Now that is simply amazing
For more information http://www.shop.gforce1320.com/produ...8&categoryId=5
Level 2 300m axles (1000+ rwhp) - regular price $999. sale price $799.
We rate our 300m Level 2 axles at 1,000+ hp simply because nobody has ever broken one. We have our Level 2 axles in 1000+ hp cars all over the world without one ever coming back broken.
For more information http://www.shop.gforce1320.com/produ...4&categoryId=5
Level 3 300m axles (1000+ rwhp) - regular price $1299. sale price $1199.
Need I say more... Our Level 3 axles get 300m billet cages making them hold even more power then our Level 2's. Ideal for for big power manual cars hitting the bottle off the line.
And again, never a one broken.
28 Spline 4340 Bolt together inner axles stubs (750hp) - regular price $550. sale price $499.
The #1 selling axle stub! Our modular bolt together design allows us to use the same cv adapter across many different platforms and also allows you to up-grade at any time to our huge 33 spline stubs simply by swapping the stub ends out.
Our bolt together design is the strongest 2 piece stub on the market. They are bolted together by 6 10mm bolts, same as your cv joints.
For more information http://www.shop.gforce1320.com/produ...1&categoryId=4
28 Spline 300m Bolt together inner axles stubs (1000+hp) - regular price $799. sale price $699.
Just like our 300m axles, our 300m stubs carry the same prestige as never been broken. These bad boys are designed to take some severe punishment.
28 Spline 4340 one piece billet inner axles stubs (750hp) - regular price $699. sale price $599.
For the guys that want the simplicity of a one piece stub but not the hefty price of a 300m stub, we designed our line of 4340 stubs to fit that bill.
For more information http://www.shop.gforce1320.com/produ...0&categoryId=4
28 Spline 300m one piece billet inner axles stubs (1000+hp) - regular price $999. sale price $899.
These are the bad boys of axle stubs, there are no stronger stubs on the market then these, hands down !
We have these stubs in cars making over 1300 rwhp.
For more information http://www.shop.gforce1320.com/produ...3&categoryId=4
33 Spline Bolt together 300m inner axle stubs (1000+ rwhp) - regular price $799. sale price $699.
These are the biggest baddest stubs on the market for the GTO, you must use our matching 33 spline spool or a modified Eaton Truetrac with these stubs.
33 Spline One piece 300m inner axle stubs (1000+ rwhp) - regular price $899. sale price $799.
Same as our bolt together 33 spline stubs but in a 1 piece design.
These babies are darn near a 1 1/2" in diameter!
For more information http://www.shop.gforce1320.com/produ...5&categoryId=4
Check out how much larger the 33 spline stubs are compared to a stock stub.
Billet outer stubs (1000+ rwhp) - regular price $699. sale price $599.
We pulled out all the stops when designing our outer stubs. If these guys look like we put them on a diet, it's because we did.
Our billet stubs are a full 3 lbs lighter then the stock stubs!
Designed to use stock studs or ARP studs.
28 Spline spools - regular price $399. sale price $349.
Nothing is as simple a spool or as strong. For the drag racer that doesnt want to spend a bunch on a posi unit and wants something that wont break then a spool is for you.
For more information http://www.shop.gforce1320.com/produ...4&categoryId=7
33 Spline spools - regular price $369. sale price $299.
Use the 33 spline stubs with this spool
Half Shaft Up-grade kits - regular price $365. sale price $299.
For more information http://www.shop.gforce1320.com/produ...5&categoryId=5
Rear Coilover kits with Strange Engineering Coilovers - Regular price $949. sale price $849.
The ultimate in rear suspension. The only true coil over kit on the market that also give you more room for larger tires when doing a mini tub.
For more information http://www.shop.gforce1320.com/produ...&categoryId=17
3.5" Aluminum Driveshafts with billet pinion yoke - regular $899. sale price $799.
The best selling Driveshaft in the business!
You cant go wrong with our PST built aluminum driveshafts. All our shafts come with our Gforce billet pinion yoke in your choice of billet 4340 steel or the super light weight billet aluminum pinion yoke.
For more information http://www.shop.gforce1320.com/produ...4&categoryId=8
3.75" Carbon Fiber Driveshafts with billet pinion yoke - regular $1399. sale price $1299.
These are hands down the best, smoothest and strongest driveshafts on the market for the GTO.
They are the only SFI certified and tested driveshaft on the market for the GTO.
They have a critical speed rating of 11,000 rpms and have been tested to hold 2800 ft lbs of torque.
Our carbon fiber driveshafts and billet pinion yokes are in the high highest hp GTO's in the world that are making 1300+ rwhp and has been as fast as 9.01 in the 1/4 mile in a GTO.
For more information http://www.shop.gforce1320.com/produ...1&categoryId=8
4" Aluminum Driveshaft and billet yoke for M6/A4, TH400 also available - regular $999. sale price $899.
This is the big power shaft for guys not wanting to part with the $ for the carbon fiber shaft.
It'll hold a 1000 hp and run down the highway butter smooth.
http://www.shop.gforce1320.com/produ...9&categoryId=8
Bolt in Fabricated 9" IRS kit - regular price $3600. sale price $3200.
You asked for it, you got it. The premier 9" kit at sale prices.
Lots of choices and options on this bad boy, everything from 31 spline truetrac posi's to 35 spline wavetrac posi's with a lifetime warranty to what color you want the powder coat.
The price does not include the pumpkin or outer stubs. Some guys like to source there own pumpkins so left that as an option. See our web site for option prices.
Our 9" kit has been well tested deep into the 9's pulling 1.34 60ft times, another proven design from Gforce Engineering.
For more information http://www.shop.gforce1320.com/produ...3&categoryId=3
Rear Toe Rod Bars - Regular price $379. sale price $299.
We designed our Toe rods to take some serious abuse, fully tig welded with DOM 1/8 wall tubing.
Heavy duty AFCO tie rod ends are supplied to properly locate the outer end, much larger and stronger then the factory tie rod ends.
Our Toe Rods also come with cnc machined bushings to properly locate and hold in place the inner hiem end.
Here you can see our Toe rods compared to the wimpy OEM rods
US made 3.91 gears (Motive) and major installation kit combo - regular price $614. sale price $549.
http://www.shop.gforce1320.com/produ...2&categoryId=7
http://www.shop.gforce1320.com/produ...6&categoryId=7
Thanks
Chris
Thanks
Chris
