answer needed please
i have done 5.7l ls1 engine swap to my 1990 chevrolet s10
i have problem with the oil pan any recommendation of what oil pan should i use without touching or modifying the cross member ??
or could any one tell me what car this oil pan come from
i really need a help on this
Did you buy the GM Muscle pan kit ?
What problem are you having... just to know what answer your looking for ! Is the front sump area is coming into contact with the engines Crossmember ? or something else?
Suggest you research build threads on other like year S10's.. and use the same pan.... or ask what problems there are with using the GM Muscle pan kit and what they did to get around it.
and the i modify it after that i had a problem which is i cannot use the dipstick i want some thing that will fit directly
