400+ what do i need?
Old 10-25-2011, 12:40 PM
jpartr's Avatar
Default 400+ what do i need?
I have a all stock 2000 ls1 camaro 6 speed, what should i do to get above the 400 mark, already thinking long tube headers and k&n filter, port and polish my heads. i want this car to be streetable but i want it to run some mean times at the track too so i don't want a huge cam but a good sized one, what do you think? what sized of intake and throtle body would be apropriate for that set up?
any help will be helpfull, thank you.
Old 10-25-2011, 12:54 PM
Stinkee's Avatar
I've seen this question asked quite a bit on here...most folks recommend full bolt ons + a mild cam & tune. Try doing a search, you should find a ton of great threads that go over this pretty well.
This thread is a great place to start:
So You Wanna Be Fast
Old 10-25-2011, 05:21 PM
garygnu's Avatar
you don't need ported heads to make 400+rwhp with a ls1 .get a ls6 intake and a ported 78mm TB.look at a good cold air intake system ,and do a good flowing exhaust with a nice Y-pipe.maybe consider talking Patrick-G or Geoff at EPS for a good cam.what heads castings do you have ?you mite meet your goal with a TSP torquer 2 or 3 cam pkg
Old 10-25-2011, 07:38 PM
TXZ28LS1's Avatar
All bolt ons such as lid, ported throttle body, catback, longtube headers and a good all around size cam like the TSP 228/228 would definitely get you there. Throw in some port work on your heads and you will be over the 400hp mark for sure.
Old 10-26-2011, 12:17 PM
Datankid069's Avatar
Here's my list of mods if you care I highlighted the important stuff.
99 SS M6, TSP MS3 Cam (.237/.242 .605/.610 112LSA), Comp Cam 918 VS, TSP PR's, FAST 92mm, 95mm TB, LFP 100mm MAFS, FTP 104mm LID w/ K&N filter, SLP cold air kit, HSW wet kit (75 shot), MAC mids and Y w/o cats, 3'' QTP cutout/ stock muffler, Optima redtop, Short shifter w/ Hurst sidewinder, UMI tubular SFC, KYB AGX shocks, eibach sportlines, OEwheels DD C5 rims 17x9.5F (275/40/17) 18x10.5R (315/30/18).
N/A: 420 rwhp 408rwtq Nitrous: (unknown) Performance tune by BSM Performance Hawaii
(Stock heads 241 cast, No nitrous, Cut out closed)
Old 10-26-2011, 01:18 PM
jpartr's Avatar
im running the stock 853 heads, they a good head?
Old 10-27-2011, 08:54 PM
lilscoggs07's Avatar
ls6 intake, port stock TB (cheap and every little bit counts), TSP cam package with 7.4 pushrods and double valve springs patriot gold, longtubes, full exhaust, good tune, good intake with k&n... there ya go
Old 10-27-2011, 08:55 PM
yeah i wouldnt bother with it unless u got plenty of $$ that u dont care to throw on some heads cause its all good if so!
Old 10-27-2011, 10:53 PM
jpartr's Avatar
what are good, affordable long tube headers that wont bottom out every where i go?
Old 10-28-2011, 12:13 AM
dannyz's Avatar
Check out Pacesetter or Texas Speed.
Old 10-28-2011, 12:43 AM
gregrob's Avatar
Just bolt ons, rowdy cam, and a tune. No problem.
Old 10-28-2011, 12:59 AM
RoidedSS's Avatar
you've got a 6 speed so it shouldn't be too rough to get there. For your headers, it's not the headers that bottom out (normally) its the y-pipe. Mine hangs extremely low. I would do a custom one with a flowmaster merge next time I change my exhaust, or just go true duals to the back. Like everyone else has said, full bolts ons and porting work should get you there with a 224 or 228 cam. A lot of vendors are very helpful on here and will get you your 400 mark with a cam and head set up.
Old 10-28-2011, 01:36 AM
ebay headers.. 170 shipped brand new if u want to save some cash honestly they are almost exact specs as pacesetters and ive had pacestters sound amazing but ebay headers sound good too... if u wanna mod the ebay headers go get the egr welded up and there ya go... thats what im getting next week on custom 3'' true duels with glasspaks dumped at axle.
Old 10-28-2011, 01:57 AM
Nick V.'s Avatar
so op its basically
Heads: x amount of $$$$
Cam: x amount of $$$$
tune: x amount of $$$
Exhaust: x amount of $$$
port and polish: free?
probalby take you 3-5k
Old 10-28-2011, 02:08 AM
imma be making 420ish rwhp when im finished with my car for around mid 1k. its all subjective if u want to blow money and u cant install cam, heads, intake, headers.. u will be spending $$$$ but if u a greese monkey and u do ur homework on what u need and how to do it, anything is possible
Old 10-28-2011, 05:07 AM
baxsom's Avatar
get a set of 243 or 799 heads (ls6 casting) from ebay. they range from 300+ for a pair. get them cleaned up if nothing else. They are good in stock form for at least 20hp over the 853s. Or you can send them to AI and for 500 bucks they can work em over a little to bump up your compression. of course an underdrive pulley is good for a few hp as well.
Old 10-28-2011, 07:00 AM
Captain Double Post
BOBS99SS's Avatar
imo dont look for a number, it doesnt mean anything, as far as what to go with it depends on your budget ,im also a fan of ebay headers, i know a few guys that run them and they are very nice, had to grind a lil more to get them to fit but they fit great , and after 2 years they still look killer, way better than my pacesetters. as for the cam , i have been shocked with how well the eps cams perform, there smaller profiles are making big cam numbers,as for heads it depends on your budget, these cars can be built on a budget just get a solid game plan together and stick to it,
Old 10-28-2011, 07:21 AM
Captain Double Post
BOBS99SS's Avatar
check out this vid in the mm section,( my h/c/i trans am in mexico )members name is Texas Ls1,this vid just shows what a good setup can do, the main parts are ported 799s,pat g cam,s60 rear,fast92/92 setup. this car hauls major *** for a head and cam car,if you can put together the right combo you will have a pretty killer ride,what im trying to say is you dont need the best heads,best parts to make a fast car, just be smart and work on your combo , it takes time and by the time your done you will want to start something new, bigger cubes,turbo or spray etc, its just how it goes lol
Old 10-28-2011, 08:19 AM
Turd Gen Guy
1nasty86's Avatar
Id do stock 243/799's, a high 22x, low 23x camshaft, and a ls6 intake with a ported tb.. A fast intake will make more of course but some cant see shelling out 600-1000 bucks for a fast when a ls6 usually makes 10-20 hp less
Old 10-28-2011, 01:00 PM
weeble1's Avatar
Im going for 400+ in my stalled auto. Ported fast 92, 95 mil tb, tsp 1 7/8, tsp ory, Borla cat back, torquer v3, yank ss3500, performabuilt level 2, the stall will eat up some of wheel hp but with a good tune I really think its possible for me in an auto. Your m6 will put down better numbers. Keep us posted.
