L92 cam swap
L92 cam swap
Would like to change the stock L92 cam to an LS3 stock cam. Plan to remove the solenoids assoc with AFM and will change lifters to LS3. Can I use the stock L92 push rods and springs with the higher lift LS3 cam?
Agree, will prob go to the LS6 springs but why the larger push rods. why not just hardened 740s?
Also, is it necessary to change the valley cover in addition to removing the soleniods?
The numbers on the back of the cam are as follows
3844
S15
8281
This all came from an 09 vette with 18K on the odometer.
250 dollars will get cam, springs and retainers shipped to your door. pushrods if you want them also.
3844
S15
8281
