higher watt foglights for my TA???
I was hoping to find some higher watt foglight bulbs for my 98 TA. What have you guys used, without frying the wires? Anybody have part #s or suggestions? Thanks.
Re: higher watt foglights for my TA???
blazertech 3200 is the word on the street.
55W with a whole aluminum housing and glass lens. Its for $59.99 from the grand prix store. Wallmart has a similar lamp called Cyberwhites for $39.99 (but I was told the wallmart version has a bluer lens which you might not like).
I bought the blazertechs 3200 from www.grandprixstore.com as they are the same ones for the grandprixs (pontiac made the same fogs for both models). Heres the exact link:
http://www.pfyc.com/store/merchant.m...ory_Code=GPEXT
Also the wires should be good enough to support the higher wattage power. But I'll double check that when I get em installed.
This link should be pretty much everything you'll need:
http://www.ls1.com/forums/showthread...lazertech+3200
There are also PIAAs 510s but those are in the $200 price range. Both PIAAs and Blazertechs (and the wallmart ones) could be used for driving lights as well. Although the headlights would be better for driving lights since they are better dispersed.
Im looking for more info on this myself so if you happen to have some more news on this let me know.
Here's a link with a ta that has the wallmart version. The lens are too blue in my opinion. Hope the blazertechs are not as blue:
http://www.metalreviewcentre.com/transam.htm
Here are some pics of the PIAAs and the Wallmart ones (keep scrolling down). Constrictor has the wallmart ones (I asked him). The ones on the camaro are the PIAAs:
https://ls1tech.com/ubb/ultimatebb.p...c;f=3;t=005117
