Thinking about using PRC LS3 heads for a moderate boost application (15-25 psi)
I just got a short block off a member on here that was built for boost. It is a Iron truck block with a 4.00 bore so it is still a 364.
I also bought a sheetmetal intake from a member on here a long time ago that was built for LS3/L92 ports. I was thinking of using a set of the LS3 PRC heads since they are an aftermarket casting with a thicker deck compared to stock ls3 castings. The only question I have is, are these heads durable enough to withstand a decent amount of boost?
Has anybody used them in a boost application?
