17" Skinny Front Wheel Weight/Price Comparison
Old 10-28-2011, 03:43 AM
glhs422's Avatar
Default 17" Skinny Front Wheel Weight/Price Comparison
Hey All!
I've been searching and searching for weights, but almost all of the numbers I come up with are for 15" front skinny rims!
I'm trying to compare these 17" front rims...
This is what I've found... (these weights are WITHOUT tires)
**17" FRONT SKINNY WHEEL WEIGHTS/PRICES** (all of these are 17x4.5, 2.25" BS)
17 weld aluma star __11.2 lb ***(see this post) ___$586 McCormack
17" weld rt-s _______13 lb from this thread ______$457 Texas-Speed
17" GTO spare skinny 13.25 lb from this post... ____PRICES VARY
17" race star skinny _16 lb 10 oz (I weighed them) _$215 McCormack
17x7 Billet street lite - 17 lb
15x4 bogarts 6 lb. $$$
15x9.5 rears bogarts 10 lb $$$
Are these weights right? Do the junkyard GTO spares really weight less than the race star 'drag stars', which are listed as 'extremely light' (>$200 each) and almost the same as the $450+ Weld RT-S rims?
17" SKINNY TIRES... from this post
M&H Radials - 185/55R-17 = 18.50 lbs//$156 SUMMIT
M&H Bias 4.5/26-17 = 11.50 lbs//$153 JEGS
**SAFETY PRECAUTION** DO NOT RUN RADIAL FRONT TIRES WITH BIAS REAR TIRES (ET STREETS, ET DRAGS, etc are bias tires)**
Here are the rims I couldn't find weights for... does anyone have the weights for these?
17" bogart skinny
Does anyone know how much a 17" bogart skinny wheel weighs/cost?
Thanks in advance!
Old 10-28-2011, 02:49 PM
glhs422's Avatar
Found this:
17" GTO spare skinny 13.25 pounds from this post
Old 10-28-2011, 02:50 PM
glhs422's Avatar
17" Skinny tires... from this post
Old 10-28-2011, 03:00 PM
glhs422's Avatar
From the Jeg's website:
I can't find a weight for the 17 x 4.5 alumastar, but....
15 x 3.5 aluma star 2.0 9.8 lb
15 x 10 aluma star 2.0 11.2 lb
so, I'm guessing the 17x4.5 aluma star doesn't weight more than the 15x10?
Until i find more accurate numbers, I'll list the 17x4.5 aluma star weight as the same as a 15x10...
17x4.5 aluma star 2.0 11.2 lb
Old 10-28-2011, 09:55 PM
223HAWK's Avatar
Not sure what my Bogarts weight but I have a 17x6..I love um, I think about $600 + a wheel..
Old 10-29-2011, 08:44 AM
Photochop's Avatar
Not necessarily a true skinny, but the billet specialties streetlites in a 17x7 weighs 17lbs and a 205/50/17 tire (depending on the brand etc) weighs 20lbs
Old 10-29-2011, 09:21 AM
ISMELLRICE's Avatar
my gto wheels with stock spare tires are 14lbs each digital scale...
Old 04-22-2012, 10:39 AM
SKULL's Avatar
WHY???
Old 04-22-2012, 08:45 PM
Camaro396's Avatar
It can cause the car to become very unstable at high speeds.
Old 04-22-2012, 08:57 PM
Mean87SS's Avatar
Yesssir.
Old 04-22-2012, 09:50 PM
HioSSilver's Avatar
my 15x4 bogarts weighed 6lb. The 15x9.5 rears weighed 10lb. Both w/o tires of coarse.
Old 04-23-2012, 09:19 PM
studderin's Avatar
I also posted alot of weights between 15 and 17 skinny setups with different tires, if you wnat to look them up. I know I posted them in the drag racing weight sticky.
Old 04-24-2012, 08:11 PM
SKULL's Avatar
im interested in the 17s stuff cause of my z06 i can only run 17s with the brakes. but why would a bias ply front differe from a radial front. i would think the radial fronts would make the car more stable because the et streets on the back with stock fronts. the car is all over the place!
my rims should show up tomorrow so the sonner i know what to pick the better lol. my choices are m/t bias ply or radial fronts. then the 7.5 inch wide hoosier fronts???? who runs those and how well are they running a 7.5 tire on a 4.5 rim???
Old 04-24-2012, 09:29 PM
Camaro396's Avatar
I have the Hoosier 26x7.5 fronts on 17x4.5 Alumastars and they work great. I also have been 120+ traps on them with my Cobra using bias ply rear tires and have had no issues.
Old 04-25-2012, 05:36 PM
SKULL's Avatar
Im leaning towards hosier or m/t I've never been a fan of m and g
SO JELLY OF YOUR CAR and I hate mustangs lol
Old 04-25-2012, 05:43 PM
studderin's Avatar
yup, know your looking for 17 only. But I posted alot of weights of different 17 tires, and 17 rims. Not just I found here, so it might help you.
17x4.5 RT-S weighs 13 lbs
https://ls1tech.com/forums/14942893-post167.html
Originally Posted by studderin
http://www.yellowbullet.com/forum/sh...d.php?t=361858
M&H 26/4.5/15 weighs 12.5 lbs
M&H 26/4.5/17 weighs 11.6 lbs
15"X 3.5" alumastar 8.9 lbs.
17"x 4.5" (only size made) alumastar 10.4
21.4 17" setup
22.0 15" setup
http://www.yellowbullet.com/forum/sh...d.php?t=357764
Re: Lightest front skinny?
all tires are 26x4.5x15 bias ply
Moroso DS-2: 12#
Phoenix: 13.5#
Hoosier: 11#
Goodyear: 10.8#
M&H: 12#
Mickey ET Front: 12#
Mickey Sportsman (26x7.50x15): 19#
Moroso ds2 - 26 X 4.5 X 15 - 13 lbs each.
kumho 165 80's - 18 lbs each
Weld drag lite 15 X 3.5's 10 lbs each
Stock torque arm: 15.57lbs
Stock torque arm with hardware: 16.64lbs
UMI torque arm p/n 2205-CM: 21.17lbs
UMI torque arm p/n 2205-CM and new hardware kit p/n 3003: 22.46lbs
Stock transmission crossmember and torque arm mount: 10.16lbs
UMI torque arm relocation kit p/n 2207: 9.93lbs
https://ls1tech.com/forums/14944177-post169.html
Old 04-25-2012, 09:21 PM
SKULL's Avatar
Ive never ran a skinny before. My buddy Bad6as has on a few cars and has always found kumho for his cars because he can run 15s. So my question to you guys is, what is the best street strip tire to run? Im trying to keep weight down as much as possible
Old 04-29-2012, 12:06 AM
breze84's Avatar
I have 2 GTO Spares for sale if any one was interested ...
Old 04-29-2012, 12:10 AM
SKULL's Avatar
would of been nice to know that before i bought my racestars!!!!!!!!!!!!!!!!!
Quick Reply: 17" Skinny Front Wheel Weight/Price Comparison
