HCI LS1 only making 423rwhp/381rwtq
Old 10-28-2011, 04:32 PM
ls69's Avatar
Default HCI LS1 only making 423rwhp/381rwtq
stock short block
etp 215 heads .40 gaskets (studded block)
cam 236/242 similar specs to MS3
fast 92 intake/fast 92 tb
42# inj
LFE 100mm mass air
lt headers full 3 inch exhaust, 4;10 gear
car made 423rwhp and 381rwtq should i not be making alot more?
Old 10-28-2011, 04:58 PM
thunderstruck507's Avatar
What's the graph like, type of dyno, what transmission, how was air/fuel ratio?
More importantly, what does it trap at the track?
Old 10-28-2011, 05:11 PM
ls69's Avatar
pulled up to about 6500ish, mustang dyno, tremec 6 speed, afr 12.93
Old 10-28-2011, 05:13 PM
ls69's Avatar
motor hasnt been to the track yet
Old 10-28-2011, 05:49 PM
1989GTA's Avatar
"mustang dyno"
That pretty much tells the tale. Like was said above you need to take it to the track.
Old 10-28-2011, 05:51 PM
ls69's Avatar
Originally Posted by 1989GTA
"mustang dyno"
will do in the spring! thanks guys
Old 10-28-2011, 05:56 PM
BrntWS6's Avatar
Looks way low...I made that with a bad cluth, 2.5 LS6 heads, and stock intake on a Mustang dyno. I'd think you should be making well over 450rwhp. My AFR was 13.0.
Old 06-21-2012, 01:56 PM
Bradlyj8Z28's Avatar
What was your trap?
Old 06-21-2012, 03:31 PM
reeperz28's Avatar
Why not pull it up higher? 6800 ish is a ms3 peak power but still low for all the mods listed. Check all the obvious stuff , throttle not opening all the way, any misfires, codes, compression check, and what matters what it mph at the track.
Old 07-08-2012, 05:10 PM
MikeWS6's Avatar
There is a dyno in my town where the average ls1 with h/c/i only throws down about what you are making. Take the same car to another dyno and it makes 50 hp more.
Quick Reply: HCI LS1 only making 423rwhp/381rwtq
