ecu swap?
Old 10-29-2011, 11:10 PM
Bowlson's Avatar
Default ecu swap?
I am swaping a ls7 in my 00 camaro z28. Do I need to swap in a c6 ecu or can I use the camaro ecu?
Old 10-30-2011, 07:38 AM
edcmat-l1's Avatar
You can use your Camaro ECU. Is this an LS7 crate motor? If so, I think you will need the crank sensor conversion box. Need to know for sure if it's a crate motor, and if it has a 58 tooth reluctor.
