Some new times with the Turbo Fox body
6.2 @ 111.xmph in full street trim, E85
My buddy Jay from HPP set some new best et's on 275/40/17 inch drag radials. Its a stock 6.0ltr, stock l92 heads with good springs, twin t3 54mm turbos, stock manifolds, ect. Custom tuned on E85....the car was run through full exhaust, as opening the cutouts adds about 100rwhp, and the injectors are marginal as is with the power its making with the exhaust closed.
Car has a good suspension setup, 1.49 60' with a borrowed torque convetor thats alittle too tight.
Sorry..i edited the post, it was l92 heads. Car is running 13psi on the hit, and settles around 11 psi. He just installed a Neal Chance th400, and it doesn't show as much power on the dyno (~640 rw with cutouts closed). But its using more fuel than it used to, so its making the power. 80lb injectors, e85 with a Weldon fuel pump. Turbos are basic t3 54mm precision turbos we speced for a H2 hummer turbo kit we built a few years ago. They are really too small, but spool fast and make the power he needs to go fast
