what RVT
what RVT
what brand of RVT are ya'll using for things such as the front timing cover (between oil pan and timing cover). on my SBC i always used "the right stuff" just wondering what everyone is using on the LS
EDIT: i looked in a book and got my answer,,, sometimes i forget about the library... sorry for clogging the forum with my nonsense.
ggino85 thanks for your response
Last edited by 3rdCoastPowerSports; 11-03-2011 at 11:18 PM. Reason: no need for this thread
LS1Tech Premium Sponsor
We use black RTV (room temperature volcanizing) silicone for most applications where silicone is needed here. We use just a dallop in each corner of the bottom of the front cover, not a huge bead all around.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
thanks Matt, that's the same thing the book i read recommended. i did put a big dab in the corners but i also ran a 1/16 bead along the entire bottom of the cover,,, maybe shouldn't have don't the 1/16 bead along the entire bottom but it doesn't seem it should cause any problems... thanks again
