does c5's Converters fit all Lt's and Lsx's cars
Old 11-08-2011, 03:13 PM
baezi z06's Avatar
Default does c5's Converters fit all Lt's and Lsx's cars
What cars can a converter from a Corvette C5 fit into
thanks
Baezi
Old 11-08-2011, 04:18 PM
01ssreda4's Avatar
C5 converters fit C5s.
Old 11-08-2011, 04:29 PM
baezi z06's Avatar
yes thats about all i know
so it doesn't fit no other cars then
Baezi
Old 11-08-2011, 05:02 PM
Circle-D's Avatar
The C5 converters are what we call a 4L60 LT style. So they will fit a 4L60 behind a LT motor. GM changed over to the LS style in the 2005 C6, although it was a special bolt pattern. Then went 6 Speed 6L80 in 2006.
Chris
Old 11-08-2011, 10:26 PM
01ssreda4's Avatar
So chris, what you are saying is an LS1/6 C5 converter will bolt up to an LT1 F-body? What about and LT1 C4?
Old 11-09-2011, 07:30 AM
Circle-D's Avatar
The Corvette C5 converter is the same used all the way back to the 700 R4, when they went to the 30 spline version. They have done a few updates along the way - clutch material, damper upgrades, bearing upgrades and furnace brazing. But they are interchangeable.
Chris
Old 11-11-2011, 07:49 AM
baezi z06's Avatar
Chris
Thanks for that Chris
i'm PM you, I need you to spec me a new Converter
Baezi
