General LSX Automobile Discussion Non-technical LSX related topics.
lq9 or ls2
Old 11-10-2011, 05:05 PM
tony.m's Avatar
Default lq9 or ls2
which do u think would be better to put in a 99 z28 a lq9 or ls2 im wanting to build a 408 stroker
Old 11-10-2011, 07:56 PM
ULTIMATEORANGESS's Avatar
Smile
i went with an ls2. im happy with it.
Old 11-11-2011, 04:00 AM
SSLSXLQ9L92's Avatar
Do you want aluminum or iron ? Lighter vs stronger.
Old 11-11-2011, 09:12 AM
rail2k's Avatar
Default b.s.
go with the 9 iron block vs alluminum iron wins unless u have a rx or smaller car and want to save weight but if weight isnt a problem lq9 are great
Old 11-11-2011, 12:28 PM
I agree, LQ9 all the way. Iron is stronger, and the weight difference is only like 60-80 lb.
Old 11-11-2011, 12:45 PM
thelsx's Avatar
if you want a stroker go with thw LQ9 stronger your only saving about 80 Lb. on the LS2
Old 11-11-2011, 01:32 PM
lemons12's Avatar
Lol at making the decision based on iron vs aluminum strength. I'm going to imagine he won't be making anywhere near enough power to worry about that.
I'm going l76.. Aluminum 6.0 with factory l92 heads.
L92s only have marginally more displacement and cost almost double right now.
Why if you have a 2800# car would you go aluminum to save weight but if you have a 3400# car you would go iron and add 80# more?? That seems 100% backwards.80#s Is a whole lot on the front end. If ill spent money on lite weight suspension, brakes, rims, etc.. Why would I not spend and extra 5-700$ and save weight with the motor?
Old 11-11-2011, 01:38 PM
Tobias05's Avatar
ls2.
weight man, weight! lol
Old 11-11-2011, 01:48 PM
SweetS10V8's Avatar
Originally Posted by lemons12
LOL at making the decision based on iron vs aluminum strength. I'm going to imagine he won't be making anywhere near enough power to worry about that.
Exactly, youll never make enough power to break the aluminum block. Strength isnt an issue, get the lighter weight.
Old 11-11-2011, 01:49 PM
I would probably just go with whatever you can find the best deal on. Honestly i just seen a couple of aluminum blocks be split all the way down the middle, and it left me feeling a little uneasy about them. probably wont happen to you though right.
Old 11-11-2011, 02:15 PM
973800CamaroRS's Avatar
Lq9 unless your wallets fat !
Old 11-11-2011, 02:35 PM
omarrakeen's Avatar
that ^, at least where i live. not sure about how much it runs there.
Old 11-11-2011, 02:45 PM
Old School Heavy
speedtigger's Avatar
I did not see anywhere about what you were going to do with this stroker. So, I won't make any assumptions as to your power levels. However, if you are going FI or big nitrous, strength might be a determining factor in your choice.
This is the thing right here. Every LS3 I see has a fat price tag. I would not spend an extra $800 to $1000 on an extra 10 horsepower, so I would not spend it on an aluminum block either.
Old 11-11-2011, 03:58 PM
tony.m's Avatar
im wanting to get around 600hp and eventually wanting to put a supercharger on it but it will probably be awhile for that.
Old 11-11-2011, 04:02 PM
tony.m's Avatar
is it possible to get 700 to 800 hp out of it without using nitrous or the supercharger
Old 11-11-2011, 04:11 PM
tony.m's Avatar
i can get the whole lq9 motor with 60,000 miles on it for $1800 and i can get a ls2 shortblock with 38,000 miles on it for $1800 not sure which to go with, with what im wanting to do to it.
Old 11-11-2011, 04:59 PM
jsmith564's Avatar
Lq9 has good fi heads.. if thats your goal get an lq9. I see to reason to buy a ls2 w/o heads for the same price. And if your pockets are deep sure you can get 700+ out of either engine but as to which one is more durable, if you have to ask, you might want to get you a mustang sir.
Old 11-11-2011, 06:34 PM
tony.m's Avatar
i know that the lq9 will be more durable its cast iron im just tryin to get a feel of what most people are going with and the pros and cons of either motor
Old 11-11-2011, 06:59 PM
zracer323's Avatar
At that horsepower level, saying that aluminum will be less reliable than cast iron is not true. The debate between aluminum and iron is really only a weight issue until you are making 1000+ hp.
If you are willing to spend a little more money, the LS2 is the way to go IMO. 60-80 lbs at the front of the car is a big deal.
Old 11-11-2011, 07:13 PM
yonerhottlt1's Avatar
If your on a budget or plan on pushing really big numbers then go with the LQ9. Me personally, I would go with the LS2 and save the weight. U can get a set of 317's(LQ9 heads) pretty cheap if thats the route u decide to take with your build.
Quick Reply: lq9 or ls2
