pedal sticks, is it slave or master cyl, at work no time to search
Old 11-15-2011, 08:18 AM
DEALERKIEL's Avatar
Default pedal sticks, is it slave or master cyl, at work no time to search
2000 ss, 68000miles, no leaks, can pump up pedal but if hold pedal to floor pressure will bled off and stay on floor, bled system last night for 30min, no help. so it is m/c or slave? thanks
Old 11-16-2011, 02:27 PM
i'm sofa king's Avatar
after you hold the pedal down in traffic or whatever, does it release right off the floor and have the pedal hang up about half way? if you lift it with your toes, it shifts fine afterwards?
if so, that sounds alot like what mine was doing. also, my fluid was turning black after 2 weeks of normal driving. i replaced my master with an o'reillys unit, and wrapped my line in high temp. tape and its been great ever since.
Old 11-16-2011, 04:35 PM
SNLPerformance's Avatar
Sounds like the master cylinder is internally bypassing, Tick has an upgraded adjustable unit that happens to be on sale currently.
Quick Reply: pedal sticks, is it slave or master cyl, at work no time to search
