Midwest Chassis Moser 9" PST UMI Performance rearend parts
Category: Drivetrain
Price: $1235
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): NJ
Item Condition: Used
LS Engine?: Fits LS Engine
driveshaft is the correct length for anyone running a 9" Midwest or Moser
rearend.
UMI Performance 1993-02 GM F-Body Tunnel Brace Mounted Torque Arm
w/driveshaft loop - Stock Exhaust & Kook LT's, CHROMOLY version, safety loop, Black powdercoated
This unit has the relocation arm mounts so will work with basically any transmission and is designed to clear vehicles running Kooks or other long tube headers with a y-pipe.
It will not clear the factory y-pipe and may not clear aftermarket y-pipes that bolt into the factory manifolds.
Both the driveshaft and the tq arm set up have only around 100 miles and they still look really nice
Price is $800 for everything,
driveshaft
chromoly tq arm, safety loop
Pictures will be up tomorrow after I get everything unbolter off the car
and take some pictures.
This is just for the 9" parts:
Umi Performance chromoly torque arm set up with ds safety loop
PST 3.5" hd aluminum driveshaft
If you needed a rear I have a narrowed 2" on each end
Moser 9" rear with 3.70 gears. Everything is new and only put on the car and
then removed that would be an extra $2500
