Pontiac GTO 2004-2006 The Modern Goat
Gforce Black Friday thru Ciber Monday sale - get 10-20% Off
Old 11-24-2011, 11:14 PM
Gforce Engineering's Avatar
Default Gforce Black Friday thru Ciber Monday sale - get 10-20% Off
It's that time of year again..
For 3 days only Gforce Engineering will be selling everything from 10 to 20% off.
The sale starts right now and will go off Monday at Midnight.
You must enter the listed coupon code to get the sale price, once you enter the code in check out the sale price will show up.
You can also call in to place your order or to ask about discounts on items not listed.
And remember, Gforce Engineering products carry a LIFETIME Warranty!
Thanks and happy Thanksgiving from the Gforce crew!
Enter BF15 COUPON CODE for 15% OFF
Level 1 4340 axles (750 rwhp) - regular price $799. sale price $679.15
You can get these in the standard diameter or the Anti wheel-hop set for the same price.
The #1 selling axle on the market!
Our Level 1 axles should really be called Level 10 axles, they have been 9.20's pulling 1.32 60ft times from a nitrous car that happens to be the fastest GTO in the country with a factory GTO rear. Now that is simply amazing
http://www.shop.gforce1320.com/produ...8&categoryId=5
Level 2 300m axles (1000+ rwhp) - regular price $999. sale price $849.15
We rate our 300m Level 2 axles at 1,000+ hp simply because nobody has ever broken one. We have our Level 2 axles in 1000+ hp cars all over the world without one ever coming back broken. Several customers have put down over 1300 rwhp on these axles.
For more information or to purchase, go here.
http://www.shop.gforce1320.com/produ...4&categoryId=5
Level 3 300m axles (1000+ rwhp) - regular price $1299. sale price $1104.15
Need I say more... Our Level 3 axles are the strongest axles on the market and get 300m billet cages making them hold even more power then our Level 2's. Ideal for for big power manual cars hitting the bottle off the line.
And again, never a one broken.
28 Spline 4340 Bolt together inner axles stubs (750hp) - regular price $550. sale price $467.50
The #1 selling axle stub on the market! Our modular bolt together design allows us to use the same cv adapter across many different platforms and also allows you to up-grade at any time to our huge 33 spline stubs simply by swapping the stub ends out.
Our bolt together design is the strongest 2 piece stub on the market. They are bolted together by 6 10mm bolts, same as your cv joints.
http://www.shop.gforce1320.com/produ...1&categoryId=4
28 Spline 300m Bolt together inner axles stubs (1000+hp) - regular price $799. sale price $679.15
Just like our 300m axles, our 300m stubs carry the same prestige as never been broken. These bad boys are designed to take some severe punishment.
28 Spline 4340 one piece billet inner axles stubs (750hp) - regular price $699. sale price $594.15
For the guys that want the simplicity of a one piece stub but not the hefty price of a 300m stub, we designed our line of 4340 stubs to fit that bill.
http://www.shop.gforce1320.com/produ...0&categoryId=4
28 Spline 300m one piece billet inner axles stubs (1000+hp) - regular price $999. sale price $849.15
These are the bad boys of axle stubs, these are the strongest inner stubs on the market, there is no stronger stubs on the market then these, hands down !
We have these stubs in cars making over 1300 rwhp.
http://www.shop.gforce1320.com/produ...3&categoryId=4
33 Spline Bolt together 300m inner axle stubs (1000+ rwhp) - regular price $799. sale price $679.15
These are the biggest baddest stubs on the market for the GTO, you must use our matching 33 spline spool or a modified Eaton Truetrac with these stubs.
33 Spline One piece 300m inner axle stubs (1000+ rwhp) - regular price $999. sale price $849.15.
Same as our bolt together 33 spline stubs but in a 1 piece design.
These babies are darn near a 1 1/2" in diameter!
http://www.shop.gforce1320.com/produ...5&categoryId=4
Check out how much larger the 33 spline stubs are compared to a stock stub.
Billet outer stubs (1000+ rwhp) - regular price $699. sale price $594.15
We pulled out all the stops when designing our outer stubs. If these guys look like we put them on a diet, it's because we did.
Our billet stubs are a full 3 lbs lighter then the stock stubs!
Designed to use stock studs or ARP studs.
Enter BF20 COUPON CODE for 20% OFF
28 Spline spools - regular price $369. sale price $295.20
Nothing is as simple a spool or as strong. For the drag racer that doesnt want to spend a bunch on a posi unit and wants something that wont break then a spool is for you.
http://www.shop.gforce1320.com/produ...4&categoryId=7
33 Spline spools - regular price $369. sale price $295.20
Use the 33 spline stubs with this spool
Half Shaft Up-grade kits - regular price $399. sale price $339.15
http://www.shop.gforce1320.com/produ...5&categoryId=5
Rear Coilover kits with Strange Engineering or QA1 Coilovers - Regular price $949. sale price $806.65
The ultimate in rear suspension. The only true coil over kit on the market that also give you more room for larger tires when doing a mini tub.
http://www.shop.gforce1320.com/produ...&categoryId=17
Enter BF12 COUPON CODE for 12% OFF
3.5" Aluminum Driveshafts with billet pinion yoke - regular $899. sale price $791.12
The best selling Driveshaft in the business!
You cant go wrong with our PST built aluminum driveshafts. All our shafts come with our Gforce billet pinion yoke in your choice of billet 4340 steel or the super light weight billet aluminum pinion yoke.
Our driveshafts are the only driveshafts on the market that are SFI approved and are the only shafts do not use some sort of adapter to connect to the u-joint. Our billet pinion yokes eliminate all adapters.
http://www.shop.gforce1320.com/produ...4&categoryId=8
3.75" Carbon Fiber Driveshafts with billet pinion yoke - regular $1399. sale price $1231.12
These are hands down the best, smoothest and strongest driveshafts on the market for the GTO.
They are the only SFI certified and tested driveshaft on the market for the GTO.
They have a critical speed rating of 11,000 rpms and have been tested to hold 2800 ft lbs of torque.
Our carbon fiber driveshafts and billet pinion yokes are in the high highest hp GTO's in the world that are making 1300+ rwhp and has been as fast as 9.01 in the 1/4 mile in a GTO.
http://www.shop.gforce1320.com/produ...1&categoryId=8
4" Aluminum Driveshaft and billet yoke for M6/A4, TH400 also available - regular $999. sale price $879.12
This is the big power shaft for guys not wanting to part with the $ for the carbon fiber shaft.
It'll hold a 1000 hp and run down the highway butter smooth.
http://www.shop.gforce1320.com/produ...9&categoryId=8
Old 11-24-2011, 11:15 PM
Enter BF08 COUPON CODE for 8% OFF
Bolt in Fabricated 9" IRS kit - regular price $3600. sale price $3312.
You asked for it, you got it. The premier 9" kit at sale prices.
Lots of choices and options on this bad boy, everything from 31 spline truetrac posi's to 35 spline wavetrac posi's with a lifetime warranty to what color you want the powder coat.
The price does not include the pumpkin or outer stubs. Some guys like to source there own pumpkins so left that as an option. See our web site for option prices.
Our 9" kit has been well tested deep into the 9's pulling 1.32 60ft times, another proven design from Gforce Engineering.
http://www.shop.gforce1320.com/produ...3&categoryId=3
Enter BF21 COUPON CODE for 21% OFF
Rear Toe Rod Bars - Regular price $379. sale price $299.41
We designed our Toe rods to take some serious abuse, fully tig welded with DOM 1/8 wall tubing.
Heavy duty AFCO tie rod ends are supplied to properly locate the outer end, much larger and stronger then the factory tie rod ends.
Our Toe Rods also come with cnc machined bushings to properly locate and hold in place the inner hiem end.
Here you can see our Toe rods compared to the wimpy OEM rods
US made 3.73 and 3.91 gears (Motive) - regular price $449. sale price $395.12
3.70 gears
http://www.shop.gforce1320.com/produ...6&categoryId=7
3.91 gears
http://www.shop.gforce1320.com/produ...2&categoryId=7
Major gear installation kit - Regular price $165. Sale price $140.25
Just about everything you could ever need to install a set of gears. Only other thing you might need is a pinion shim kit.
Thanks
Chris
Old 11-24-2011, 11:38 PM
Rocksteady's Avatar
PM sent regards to shipping!!
will take a set of half shafts and inner stubs!!
Brett
Old 11-27-2011, 08:37 AM
Brett
Got it. Thanks!
Quick Reply: Gforce Black Friday thru Ciber Monday sale - get 10-20% Off
