my plans: how long will it last/what i need?
alright guys.after reading the thread about stock long block's on bost and figured id ask about a setup i was thinking about when taxes come in.
background on the car can be found on this link:
https://ls1tech.com/forums/introduct...newbie-tx.html
but to cut it short,as far as i know,the long block is bone stock.
mind you,im used to gen-1 sbc's and hearing that people were running boost on 10:1 compression made my brain hurt
but here's my plan.
P-1SC procharger kit @ 5lbs of boost.
upgraded clutch from centerforce(or others)
and a tune.
question(s): what all do i need to do/upgade for this? i figured at 5 lbs,i wouldnt really need to worry about a new fuel pump or injectors. i may do the injectors for ***** and grins anyway. i dont plan on ever going over 5lbs of boost seeing as i like pumpgas and its gonna be my DD'er. before i ramp the boost up any higher,ill be tearing into the engine and that wont be for a good while. what would my EST. milage look like? also,how long do yall think the engine will last? i aint gonna be racing it much,if any and im not gonna rev more than 6K rpms no matter what.
thanks for yalls help and probable flaming.llol
but here's my plan.
and a tune.
i found this kit for $216.99.
http://www.texas-speed.com/p-2356-ra...ic-system.aspx
says it can handle up to 700rwhp.what you think? also,what size injectors should i look at? 42lb/hr or so?
