Can I run 15"s on the rear?
Old 11-28-2011, 03:08 AM
Junkyarddog89's Avatar
Default Can I run 15"s on the rear?
Noob question but can I clear 15" wheels on the rear of an '02 Camaro? I have a set of drag radials in a 15 and it would be nice if I could use em. Thanks.
Old 11-28-2011, 03:59 AM
Captain Double Post
BOBS99SS's Avatar
yes you can lol, depends on the rim if you have to do any grinding,studs,spacers, etc what rims/tire setup do you have?
Old 11-28-2011, 06:23 AM
Camaro396's Avatar
Depends, only certain wheels will clear your brakes. Only Weld Racing RT wheels, RTS wheels, or Bogarts.
Old 11-28-2011, 09:44 PM
I got 2 245/75R15 Nitto Radials layin around and a couple of 15/8 steel rallys layin around... It's probly wishful thinking but it would be sweet if I didn't have to buy anything.
Old 11-29-2011, 05:35 AM
Captain Double Post
BOBS99SS's Avatar
yeah im not sure those are going to work , like camaro396 said only certain wheels will just bolt right on, and sometimes you still have to grind a hair for them, have heard good things from the weld rts though
Old 11-29-2011, 07:36 AM
Camaro396's Avatar
Those will not work, and they are probably not near the correct backspace.
Old 11-29-2011, 07:10 PM
Thanks guys, I guess I know deep down they wouldn't work but figurd I'd check. 16" will clear with no problem though right?
Old 11-29-2011, 08:21 PM
Camaro396's Avatar
Yes sir. Or even 15" Weld RTS will clear.
Old 11-29-2011, 11:53 PM
Right on thanks for the info guys.
