ken bell booster pump 150shot
Old 11-28-2011, 05:28 PM
blow thru's Avatar
Default ken bell booster pump 150shot
Im currently running bolt ons only and about to get a tune and wanting to spray 125-150 and wanting be safe not maxing out the standard pump. I only plan on spraying a couple of times a month so could i just get away with a bap. Thanks
Old 12-02-2011, 02:35 PM
blow thru's Avatar
Anyones thoughts on a bap?ive done some searching and still unsure how this will effect my pump in reliability.It saves me dropping the tank to do the 255
Old 12-02-2011, 04:07 PM
ducatisl's Avatar
Okay, I'll jump in: You should figure out how much total rwhp you're going to put down. Subtract your all motor rwhp and what you're left with is how much you theoretically can spray. Datalog your AFR and rail pressure and make sure the AFR stays reasonable and the rail pressure doesn't drop significantly.
This is why people use standalone fuel systems.
Old 12-02-2011, 05:27 PM
Sales1@Texas-speed's Avatar
I would recommend just upgrading the factory pump with a kit from Racetronix which will supply more than enough fuel to handle the mods you have.
