my trans just went out need opinions
Old 11-30-2011, 09:44 PM
1964h's Avatar
Default my trans just went out need opinions
well my 4l60e out of my 98 camaro just burnd 3rd gear clutches after coming back from track .it is a new built trans this is what i had installed in it red clutches with an extra set im not sure if its the z pack, corvett servo, wider band with new front pump.the builder is going tov open it hopefully soon to see what happened .well to begin with i think its barely enough to handle the hp of my motor so im thinking i should have a trans that will handle and excced what my motor is producing .my trans has about 1k miles on it i just went to track ran 11.70 nxt day or so is when i noticed it slippn in 3 completly. im just thinking what trans are good wit no doubt i should be pushin around 410 to 430 rwhp i was looking at performabuilt stage 2
Old 12-01-2011, 12:07 PM
ProTreeRacing's Avatar
If you'll take the tie to call I can help you understand different options that are out there!
g
Old 12-01-2011, 01:05 PM
LT1allday's Avatar
give andy at finishline performance transmission a call you won't regret it great stand up guy and they build great transmissions, check thier reputation here on the forum
Old 12-01-2011, 11:39 PM
1964h's Avatar
ok thanx for the replies.ill look into both
Old 12-02-2011, 08:06 PM
NVR_SPDS's Avatar
Dont forget RPM Transmissions!! Best customer service I have EVER received, and their builds cant be beat!
