whats all need to do ls6 intake swap
whats all needed to switch the ls6intake on my 98? i know the intake coolant pipe and plugs i dont really know what these 2 things are needed for but in nknow i need them. what gaskets etc. will i need. thanks
A new LS6 intake manifold should come with the replacement gaskets. The 98-00 Coolant pipe runs down the center of the engine under the concave part of the ls1 intake. Since the LS6 is flat, there is no place for the coolant pipe. So, like the 01+ the rear holes get a plug in each of them, and the new coolant pipe just connects the front holes. Oh, you may want a Oil Pressure Sending Unit on hand for when you brake it LOL, just make sure you unplug EVERYTHING off the back of the intake before you go tugging at it.
If you want install instructions here www.ls1howto.com
When you order - from one our great sponsors - make sure that it comes with the rear block off plates and the front replacement pipe.
David
David
