Generation IV Internal Engine - AFR245s or TFS245s for 434ci sleeved stroker?
Snyper
12-04-2011, 05:41 PM
Im about to order one or the other tomorrow and I was wondering if anyone had any recommendations or more info on either of these heads.
LT1Formula007
12-04-2011, 08:51 PM
I would talk to TEA or Brian Tooley about the TFS 245's personally.
I know there was an option to have powdered metal valve guides installed with the TFS heads, therefore you can still retain use of the stock rockers and do a trunion kit upgrade to them. That'll save you some $, and take all the added weight off the tips of the valve that are added with aftermarket roller rockers. Just my .02, But both are GREAT Heads. :)
Good luck in your decision, But I know what I'm going to run on my setup.
James
Stang's Bane
12-04-2011, 08:55 PM
Both are great. Take a coin and flip it...
FlamingTA
12-04-2011, 10:59 PM
Both are going to be pretty good. My vote is for the AFR's but it's kinda personal choice. If you are going to run a pretty aggressive lobe and/or high lift I would use a good aftermarket rocker instead of the stock ones.
Samer
12-06-2011, 04:36 AM
Both AFR and TFS have great heads with proven results but I'd recommend the AFR 245 and to get maximum performance, you can have them ported by Tony Mamo.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
