what springs n pushrods for torquer v3 111 lsa in a 2001 5.3?
was wondering which springs n push rods are common for this cam in a 2001 5.3 any insight and info is greatly appreciated thanks guys
With the Torquer V3 I would recommend running the PRC .650 dual springs. As far as the pushrod you'll want to purchase a chromoly set and a common length is 7.400 assuming your using a stock cylinder head with a stock gasket. Always measure to be sure on proper length though.
They come with drop in seats to accept the dual springs. Most just install and go with very little issues. I recommend measuring spring height and shimming accordingly.
LS1Tech Premium Sponsor
No machining required for the PRC .650"s.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
