Stereo & Electronics - alarm on 2003 silverado
bigpappasz28
03-14-2004, 12:22 AM
Just wondering if someone has installed a remote start alarm and window roll up on a 2003 silverado?Where can i get a wire diagram on that truck,i have the alarm and was going to install it my self due to shops charge alot to install,ive don it before but they say the 2003 silverado has diferent wiring than older models,need wire diagrams
bigpappasz28
03-14-2004, 03:16 PM
anyone know where?
bigpappasz28
03-14-2004, 08:09 PM
need help?need wiring digram
SSactionLs1
03-15-2004, 08:04 AM
Constant 12V+ Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Ignition 2 White Ignition Switch Harness
Ignition 3 Brown Ignition Switch Harness
Accessory Orange Ignition Switch Harness (Heat/AC)
Tach White V6 Coil, If V8 at Any Coil, 1 Cylinder Setting
Brake Switch White Brake Switch
Trunk Pin n/a
Parking Lights Light Blue (+) Light Switch
Head Lamp Yellow (+) Light Switch
Factory Disarm Light Green (-) Keyless Module
Door Trigger Tan DR. (-) Light Blue Passenger's Module below Steering Column
Door Lock Light Blue (+) Keyless Entry Module below Steering Column
Door Unlock White (+) Positive Trigger
Driver's Lock Gray Driver's Kick Panel
Driver's Unlock Tan Driver's Kick Panel
Passenger Unlock White Driver's Kick Panel
Horn Wire Black (-) Steering Column
Windows Up LF=Dark Blue, RF=Light Blue
Windows Down LF=Brown, RF=Tan
bigpappasz28
03-15-2004, 05:28 PM
where did you get this info?do i need any special modules?
SSactionLs1
03-19-2004, 04:50 AM
you will need a 555L or 555T which is a module that emits the signal from your key to the ign. And i believe your door locks require a 5 wire (relay)
bigpappasz28
03-19-2004, 04:08 PM
do you know where can i get the digram to show where the wires are at on the 2003 silverado?Ive herd of directtech but you need a pasword to get any info
SSactionLs1
03-20-2004, 01:44 AM
www.the12volt.com
bigpappasz28
03-24-2004, 03:41 PM
thanks for the site,but you need a password to get the wiring diagrams on that site.Do you have a password?
thanks for the site,but you need a password to get the wiring diagrams on that site.Do you have a password?Very good info since I am the market for an alarm. I was wondering the same thing about the password.
bigpappasz28
03-25-2004, 12:52 PM
does any one have the a password to get in the site?
unredeemed
03-25-2004, 01:28 PM
Taken from website home page
Joining is free and simple, and includes access to our vehicle wiring database.
bigpappasz28
03-25-2004, 01:41 PM
Does anyone have the password to the site to get the diagram?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
